Question about Frigidaire Kitchen Ranges
Frigidaire stove model #FGGF3054MF OVEN GOES OFF IN ABOUT TWENTY MINUTES AND 2.30 COMES ON THE DISPLAY
CHANGING THE ELECTRONIC CONTROL BOARD
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon friend, thank you for your post!
I see that you are having some difficulty with your Frigidaire range displaying a 2:30 and cutting off. This sounds like a wiring issue or a control panel problem within your range. I would recommend performing a reset and you can do that by disconnecting power to your range by flipping the household circuit breaker and leaving it off for roughly ten minutes. If that does not help to resolve the issue I would suggest having a professional technician come out and accurately diagnosis your range. Best of luck! -Matt
Posted on Feb 17, 2015
SOURCE:
  • 213 Answers
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Posted on Nov 21, 2007
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire Classic Range, Model # FEF366CCB, F1 error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^%$RF
Posted on Oct 01, 2010
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
I have the Frigidaire Gallery slide in stove/oven. The display for temperature is so dim that I can't see it anymore. Would it be a fuse?
The Electronic control has lights inside for the time and for the temperature. Over time the lights get dim (Frigidaires do it a lot). The Electronic control is not a Servicable part. You must buy a new Electronic control.
Apr 09, 2012 | Kitchen Ranges
I HAVE A FRIDGIDAIRE STOVE AND OVEN MODEL #PLES389CC SER. #NF54421685 AND WHEN TURNING ON THE OVEN IT GIVES A F 13 CODE. WHAT COULD THAT BE?
Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
May 31, 2011 | Frigidaire Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
We have a digital display on our Frigidaire stove it is not working and nor is the oven. The elements are fine. Any suggestions please?
Hi.
A technician should read voltage to the electronic oven control board, to test the EOC in full. For safety reasons testing hot wires is an operation that must be done by a repairman.
If there is no power to electronic control, then the wiring harness must be replaced.
If the oven control display is blank I would exclude that the problem is being caused by faulty element, faulty temperature probe, or defective door latch, all this faults do not cause the display and controls being non-responsive.
Most ovens have display, control board and pads as separate parts, in that case the connectors between parts in the control assembly must be tested.
Parts and diagrams for most models are available here.
Regards.
Ginko.
Mar 02, 2010 | Frigidaire Kitchen Ranges
Oven just turned off
It sounds like your microprocessor in your control board is damaged. You can leave the power off for as long as a week to see if it will reset. If it comes up the same way, it's an electronic problem with the display driver. Frigidaires usually display an "F1" code. Any way, power down, wait at least 3-5 days, power up, clear, reset time and see how it goes. If it happens again, you may have to get a new oven control board/display.
Jul 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Aug 29, 2008 | Frigidaire FEF355 Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Feb 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
112 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
