SOURCE: I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: Standby LED blinks in red continuously KDL-46XBR4
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV. I will forward a link to a page where you can get more information and troubleshooting steps for this issue. http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467 Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
SOURCE: sony bravia kdl-40s5600 are on st by and red led flashing three times
Over voltage protection is going on. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
how does a reset fix anything related to a LowB Error?
the symptom he described was: turn on, blinks green trying to get past self-check, then goes immediately into LowB Error.
reset won't do diddly
