We have a RCA DVD which is in the motor home . We have 2 cords going to the TV. We put TV on HMl and that did not work as well as HM2 and also video. nothing works
SOURCE: JVC AV-27820 27" TV
Im sorry your having this trouble But I cant tell you whats wrong as I havent looked at the set. The problem could be a simple power supply problem or a cold solder connections in the horizontal sweep circuit. If your not a tech this is not a job for an experimenter or tinker . There is hi voltage in these sets even when they are unplugged so you are gonna need to call a pro in to assit you in this repair or geta new one > good Luck
SOURCE: cannot get 27" jvc av-27530 tv to recognize playstation 2
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
SOURCE: my jvc tv has good sound but nothing showing
if when you turn the set on the display does not light up at all there is a good chance the display has gone, if you ring jvc they should be able to giv you a price of a new dsplay i will warn you it wont be cheap.
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
