I have replaced the lights switch and the tail lights bulbs.
Get the wiring standard for trailer socket on car / caravan .
Something like this
http://www.caravantalk.co.uk/caravan-advice/new-to-caravanning/electrics-guide/12-volt-systems
Then get a 12v probe and test the voltage is coming out the correct pins on the car when the tail lights are turned on.
http://www.amazon.com/6-36V-Circuit-Test-Probe-Indicator/dp/B0065R1CK4
Check the Earth Connections on the caravans tail lights.
Check the Caravan has an earth connection to the car body.
https://caravanchronicles.files.wordpress.com/2012/01/caravanchronicles-wiring1.jpg
see how pin 3 shows an earth wire it would have a wire on car socket pin 3 going to the car body. If the earth wire is corroded or broken I think the tail lights on the caravan would not work. It may be a different pin on your setup .
