Heating & Cooling Logo
Posted on Feb 12, 2015
On a Lasko model 751320, is there a way to mute the beep sounds when you adjust the controls?
2 Related Answers
Anonymous
  • 4736 Answers
  • Posted on Feb 17, 2011
SOURCE: I recently hear there is
According to the Consumer Products Safety Commission http://www.cpsc.gov/cpscpub/prerel/prhtml07/07227.html there was a recall of your model heater in 2007. Does this effect yours? Depends on whether or not yours was manufactured prior to this date. Even if it was, recalls and reimbursement for what you may have paid for the heater has time limits for you to make a claim.
Click on the above link for more information.
robertedw51358
Robert Fay
  • 9 Answers
  • Posted on Jan 23, 2015
SOURCE: i do not have a
Try: http://bit.ly/Lasko_Ceramic_Tower_Heater_MANUAL
Lasko Fan model 4920. Can I get a replacement remote for it please?
Lasko Fan Remote Control Replacement
Amazon.com https://www.amazon.com > lasko-fan-remote-control-r...
Master Replacement Remote Control for These Lasko Fans and Tower Fan and Heaters only (Models List #1) Universal Only for The Heater and Fan Part in The Right ...
Missing: 4920 ‎' Show results with: 4920
Parts Store - GuardianTechnologies
GuardianTechnologies https://lasko.com > pages > parts-store
Whether you want to replace a lost remote control, need a new set of box fan feet, or are ready to replace filters, the Lasko parts store is available for ...
Remote Controls For Lasko For Fans
Remotes Remade https://remotesremade.com > collections > remote-cont...
New and Used Remote Controls For Lasko For Fans. We have 3 options for each fan. Official remotes, Alternatives and Universal. Prices from $29.
My Lasko Ceramic Heater is beeping every 5 second, how can i get it to stop?
It sounds like the beeping and flashing issue on your Lasko Ceramic Heater might be related to the clock setting. Here's what you can try:
Unplug the heater for a few minutes to ensure it's completely powered off.
While it's unplugged, try to reset the clock to the correct time by pressing the appropriate buttons on the heater's control panel. You might need to refer to the user manual for specific instructions on setting the clock.
After setting the clock correctly, plug the heater back in and see if the beeping stops.
If the issue persists, it's a good idea to consult the user manual or contact Lasko customer support for further assistance, as there might be a specific sequence of buttons to reset the clock or troubleshoot the problem.
2answers
My Avanti microwave keeps beeping nonstop.
Hi.
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.)
If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
If you've tossed the owner's manual to your microwave, check the manufacturer's website. They will often provide a digital version of the manual as a PDF for more recent models. For an older model, you may need to do some digging, but a great start is to just do a Google search for "[microwave brand and model number] manual."
Once you have the PDF version of the manual, press Ctrl + F on Windows or Command + F on Mac to search the PDF for "mute," "sound" or "beep."
Good luck.
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
2answers
I need a manual for a ceramic element air heater, model 5126
Try:
2answers
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. [email protected] If you prefer to call them the number is 800-233-0268.
Hope this helped you.
I recently hear there is a recall on some Lasko heaters. My model is 751320. Is this in he recall? [email protected]
1helpful
I don't have an owner's manual. Can I obtain one for free?
The answer is yes you can get one for free. You can download the manual here:
http://www.laskoproducts.com/instructions/751320%20Ins%20751320ESnew.pdf
If we can be of further assistance just ask. Thanks for choosing FixYa,
Kelly
Top Lasko Heating & Cooling Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
