Not sure on the diesal pump but if there the same not a gard job the pumps under tge car basically under the dricers side rear seat held in place with a plastic holder remove tge plastic holder 3 or 4 10mm plastic nuts the pump has a wire going to it remove this then there are 2 pipes 1 in from tank 1 out to engine unscrew these and replace
Not a good thing. Turn it off, let it cool down and try rebooting (hard reboot). My SONY is a model that has an overheating problem and it did that a couple of times before finally losing the video. They replaced the motherboard and it has held for awhile but is going again. Hope you backed up. I now always run on a cooler - bad design.
Shut it down (not hibernate), remove power supply and remove battery. Wait 30 seconds before reinserting battery. Boot the system.
In this doesn't solve the issue, your keyboard might be dirty. In that case you should clean it. Be careful if you choose to use a vacuum cleaner that you take measures to prevent your keys from getting into the vacuum cleaner.
This is I read from another site, the mp3 player must be on in order for it charge. Make sure the power is on. Next if you are not using it make sure you turn it off, because even if it goes into shut down or low power mode it can still drain the battery.
