RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
Posted on Aug 03, 2017
I have a blackberry pearl flip phone and when you change the settings for the ringer to vibrate or silent it does this action just fine. However, when you set it back to my advanced settings or the basic ringer itself, the phone displays that the action was successful but it stays stuck on vibrate or silent. The only way to get it working again is to pull the battery and reset it..... what the @#*%?
5 Related Answers
A
Anonymous
  • Posted on Dec 22, 2007
SOURCE: Stuck on silent mode and cannot get the ringer to ring
rings
Anonymous
  • 407 Answers
  • Posted on Jun 01, 2009
SOURCE: Rim Blackberry Pearl flip 8220. Cannot retrive MMS pictures
By retrieve do you mean you have already recevied them and they are no longer visible to you?! If so check the following.
You may have already tried some of these options, but for the sake of completeness.
Check your icons are not hidden. From desktop/ Options/ Show All.
The MMS Data - MultiMedia Messages may be stored along with
your Text messages - check this folder.
Check all your Media folders - including My Pictures and Preloaded.
Failing all of the above - Check MMS in Options and MMS and do the same for Media Card.
If you connect your Blackberry to your PC you will be able to see all stored files and their location..
If you are not able to receive them in the first instance - You will need to enable yout Blackberry to receive them by MMS in Options and checking this option in addition your Network Provider will need to send you settings to store.
Anonymous
  • Posted on Jul 16, 2009
SOURCE: blackberry flip pearl constantly reboots.
I've had the same problem, particularly after upgrading the OS. I've been able to keep it reboot free for 24 hours after resending the service books from the bberry portal (and I'm even using it unlocked from T-Mobile on AT&T).
Tim Digibrain
  • 846 Answers
  • Posted on Jul 27, 2009
SOURCE: Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Anonymous
  • 625 Answers
  • Posted on Sep 01, 2009
SOURCE: External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
on the outside of the phone below the
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 • Cell Phones
1helpful
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
2answers
Shoing call coming in but not ringing
Hey there, Check that your profile is not on Meeting or Silent. It it is, change it back to General. It should then work.
If not, go to your settings and change the ringtone, its probably on silent, so change it to "Ring & Vibrate".
I hope I helped you & that this post is helpful to you at most! Don't forget to rate! ;) marinora_38.jpeg
1helpful
My phone will not ring at all i have tried taking the battery out..it will only vibrate
Blackberries...hahah my specialty. Go to the sound section, click on Set Ring Tones/Alerts and make sure that you are on a Normal Profile. If you are, then make sure your ringer volume is not set at "vibrate"
Got a new Blackberry Storm and my ringer won't ring
Check either your profile or under "Options" -> "Sounds and Ringer Tones" and see if your volume is set to "Silent". Change volume to something other than "Silent" and see if your ringer works then.
1helpful
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
Not recieving calls just getting the missed call
Check settings to assure the ringer is on. Rather than silent and/or vibrate mode. Sorry I can't provide much more than that. It's difficult to say without having more details.
2answers
I AM HAVING THE SAME PROBLEM. PHONE WILL NOT RING.
you need a ringer speaker I can help you contact me i can help you repair your phone
wirelessrepairsaws @ yahoo dot com
I have a borowed Blackberry Pearl. I can't figure out how to turn my audible ringer "ON!" Among many other issues but, I can't hear when my phone has an incoming call! Help please?
Go to profiles and make sure it's not in "quiet" or "vibrate" mode. If it is, choose either normal or loud.
If normal or loud are already selected you may need to go to advanced settings (at the bottom of the profile list).
In the advanced menu, click on the active profile, then choose phone. Make sure it is set for "tone" or "vibrate + tone" in both the out of holster and in holster sections.
-Neil
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
