Boating Logo
K
KYRIAKOS KALAMATIANOS Posted on Feb 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own a JRC 1000 radar on a 31' sailboat. It was working trouble free for years. Last summer, it started shutting off while operating. What can I do to fix it?
After its shutting off, let it cool for a while and then, when I press "Power" again, it works, until shutting off again.
Brendan Gee
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 25, 2023
Brendan Gee
Contributor
Level 1:
Answers
Questions
0
Helped
648
Points
Hi if you want to sell the scanner or whole thing I'd be very interested as I have a mint display unit but didn't come with a scanner
Penzance Computers
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,003 Answers
  • Posted on Feb 12, 2015
Penzance Computers
Master
Level 3:
Renaissance:
Answers
2003
Questions
0
Helped
337373
Points
7859
Open it up, dust it out, and generally clean it.
Testimonial: "Thank you, I will try it. Do you think it's happening because of humidity and salt water?"
JRC JMA 2213 Marine Radar. Radar error message be/bearing pulse error. Model JMA 2213
Question edited for clarity.
Question moved from Office Equipment category to JRC Radar.
The pulse generator is in the dome. Check all the connectors for corrosion. Help in the link and it is a common error. It sounds like you need a new 'professional'.
https://www.google.com/search?q=JMA+2213+bearing+pulse+error
1helpful
Radar jrc 1000
Buy a new one. If it did, it probably fried the controll chips.
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 • GPS
2helpful
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Troubleshooting a JRC 1000 marine radar unit
Hi does any one have a scanner for a jrc1000 they would sell me please can not find one for sale anywhere.
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
2answers
Hello, I need a power cable for my JRC 1000. How
Hello there,
I also need this very same power cable. Did you find one already? maybe you can tell me wich one of the 7 input connections is the + and - DC power connection so I can connect this thing myself with a home made power cable. Greetings. Stan (holland)
[email protected]
Thanks!
1helpful
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
1helpful
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
[email protected]
Jun 13, 2008 • GPS
Top JRC Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a JRC Boating Expert? Answer questions, earn points and help others
