Re: My door will not open on my washer and it will not...
Try pulling the handle with youre left hand kind of hard & at same time push in on door with right hand close to handle work it back & forth if that don't work try jerking on handle with left hand with right one on machine gasket maybe stuck or handle broke inside door hope u luck Nick
i forgot the lock switch may have door locked turn it to washcycle then to off & try opening doori forgot the lock switch may have door locked turn it to washcycle then to off & try opening door
You can't post conmments that contain an email address.
Daewoo Washing Machine Error Fault Code = LE Fault Detected: Washing Machine Door Open Washer Has Detected: Washing machine detected door as open or not locked Check / Repair / Fix = Close door ā Door lock switch ā Door latch ā PCB
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
This error code indicates that the door is not locking. Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it. Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
