Connect net flicks
SOURCE: connection to internet on wii system
try to set your channel to either 1 or 11.set also your router's broadcast setting to 'mixed'.place your wii near router with no interference from microwaves or such.if router setting is set up to allow only selected pc's (or mac addresses),don't forget to include wii's mac address to enable it to have access to the router.if your router password type is wpa,make sure also you know whether it's wpa-psk AES,wpa2-psk AES or wpa-psk TKIP,you need to consciously choose the right one on your wii internet setting.also,you could switch the dns ip addresses around like put 2nd ip address in primary and 1st ip address in secondary.no guarantees,hope this helps.
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
SOURCE: cannot connect to internet error code 51330 is
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
Need more info? Check Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
SOURCE: can not connect to the internet error code 51330
Error Code: 51330This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
