Question about Frigidaire Refrigerators
"OP" what is the meaning of this code refrigerator frigidaire
    Problem Solver:
  • 11 Answers
OP stands for open thermistor. You must likely have bad wiring, connector, or bad thermistor. I recently found a newer SxS frigidaire refrigerator that had OP displaying and would occasionally show negative numbers on fresh food side. The thermistor wiring harness and plug that had found it's way into the condensate pan under unit. Wiring was compromised to the point of having to install new connectors and remove the plug.
Posted on Sep 14, 2016
  • Official Brand Answer
  • 2,267 Answers
Good Morning friend, thank you for your post!
I see that your Frigidaire refrigerator is displaying an "OP" error code and you want to know what it means. An "OP" could stand for open thermistor. This could be a possible problem with your thermistor or control panel. In any case that it is a false error code I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for roughly ten minutes. If that does not help resolve your issue I would suggest consulting with a professional technician for proper diagnosis. Hopefully this is helpful information. -Matt
Posted on Feb 13, 2015
SOURCE:
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
I have a frigidaire refrigerator with electronic screen about a wk ago started beeping giving me a code of sy ce what does this mean?
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
May 26, 2015 | Frigidaire Refrigerators
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
What does frigidaire error code 3 mean
Thanks for your post, friend!
From what you are describing your display is showing an error code "3" on your Frigidaire refrigerator. Typically a "3" stands for your fresh food sensor has shorted. Which means the thermostat could need to be replaced or the wiring between the board and thermostat could be an issue. I would recommend you perform a reset on your refrigerator.
You can reset it by unplugging the power cord or flipping the household circuit breaker for ten minutes. If that does not correct the issue you may want to seek assistance from a professional for proper diagnosis. Hopefully this helps to some degree. -Matt
Oct 04, 2014 | Frigidaire Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What does the OP2 code mean
OP means sensor is open OP2 would mean sensor number 2 is open
Sep 10, 2013 | Sanyo SRR49FD
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
Frigidaire error code 4
Error code 4 usually means that there is a communication failure with the main control board and damper. Base on the intensity of the issue; contact a professional technician to diagnose the unit to assist with the repair.
Sep 12, 2012 | Frigidaire Side By Side Refrigerator 26...
Frigidaire side by side error code 4
I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
Thanks, Anibal
Oct 30, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
2,059 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Carmen Mikulic
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
