Question about Viking Dishwashers
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE WATER SHOULD BEGIN DRAINING FROM THE VIKING IT JUST KEEPS WASHING AND THE TIMER REMAINS WHERE IT IS. WHAT IS WRONG??? DO I HAVE A BAD DRAIN PUMP, OR IS IT SOMETHING ELSE???
    Genius:
  • 1,075 Answers
Yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Posted on Feb 12, 2015
SOURCE:
Dishwasher not cleaning dishes
hi paula.
Insufficient water in the dishwasher also can cause poorcleaning. If the float gets stuck in the raised position, thedishwasher won't fill with water (Photo 3). Another likely cause is a clogged inlet screen or faulty inlet valve. ... To determine if your dishwasher is getting enough water, start a wash cycle.
Dishwasher Repair Tips: Dishwasher Not Cleaning Dishes ' Family ...
https://www.familyhandyman.com/.../dishwasher.../dishwasher...dishwasher-not-cleaning...
Dishwasher not cleaning dishes Google Search
Nov 02, 2017 | Dishwashers
My GE Nautilus portable dishwasher will take water in, the motor will hum for a few minutes and then drain out into the sink. This process repeats but the water never cycles inside to actually wash the...
Try manually adding water to the dishwasher. If it works then the water valve is just clogged. Sometimes it gets full of gunk and the machine will take in water but not enough to run properly. It is in the upside down cup shaped thing on the bottom left front. The other possibility is the Cam/Timer. It is in the door right behind the dial. This is the part that triggers all the different actions.
If when you add water it doesn't work then the valve or the solenoid on the pump assembly is likely done.
Feb 24, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
Hello -- I am having issue with this dishwasher! Water pools at the bottom and dishes are not getting clean!!!
Your pump is worn out. Time to get it to a repair man or get the manual out and if you feel handy be ready for some major expense and time.
Feb 14, 2011 | Viking 24 in. Professional Series VUD141...
My dishes dull and and the glases have a fulm on them. Both dishes and glasses just don't have a "clean" feel to them. I've checked the arms for blockages and clogs, water temp is fine, and the...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 08, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher stops during various cycles and does not clean dishes
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 30, 2010 | Jenn-Air JDB3610 Built-in Dishwasher
The dishes are not coming out clean, how do i fix the dishwasher so that it works at full efficiency?
Check the rinse aid setting is according to the user manual. Also use longer cycles for better wash results. Make sure the proper salts are used if you are in hard water area.
If problem is not resolved then buy Finish dishwasher cleaning kits from super market and run each drawer on long cycle with kit located in it according to instructions.
Hope this helps. Please rate this solution to help fixya help you better in future.
Aug 22, 2010 | Fisher and Paykel 23 in. DD603H SS...
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
Viking VUD141 advances through the cycles but won't drain water
The unit should be installed with a high loop in the drain line at the rear of the unit. If this is not in place it can cause the drain water to run back into the unit. If there is a partial blockage it could result in incomplete drain. Try disconnecting the drain line below the sink and run the unit to drain into a bucket see how it drains. would be a sign as to how free your drain line is.
It could also have defective drain pump
Jan 10, 2009 | Viking 24 in. Professional Series VUD141...
Kenmore dishwasher
Check the motor pump housing for an obstruction on the impellor. Impellors can go bad and not actually churn the water around the way they are supposed to.
Jun 22, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher won't wash!
check the sump screen on the bottom of the tank for clogs.also check the wash arms
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
187 people viewed this question
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Craig Butler
Craig Butler
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
