Nothing
Ebay was selling one for a few dollars in working condition, you are better off buying a used one or a none working one making sure the battery door is good. You can replace the battery door but it will require you to take the front and rear cover of the camera off. You will have to take off the little screws all around the camera and the pry apart the front and rear case.
Sometimes you can use a pair of small needle nose pliers and just squeeze the ends of the plastic battery door inwards from the hinge and the battery cover should pop out. To install the new battery door you do the same, squeeze the plastic axle and push it into the cameras case.
