My instructions are in spanish but I did figure out volume is at 5 I had this phone for 3 months it was working fine than When it rings I can barely hear it
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
To lower the volume:
Hope these steps help!
Regards
Gaby
Motorola Customer Care.
SOURCE: volume
Dear My Fritz
Ear piece volume can not be adjusted unless you are on a call.
So
Ring your phone , answer the call and then hit the volume button's to saise or lower .
Regards Mobile maniac
SOURCE: CAN'T HEAR RING TONES ON MY RAZR V3I CELL PHONE
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
SOURCE: I can barely hear people speak.
To adjust the volume on the Nokia 2600 simply have someone call you and use the "arrow keys" to the left and right of the "menu" key. The volume will show as a line bar, the center of this bar is adequate for most people. When you hang up, the setting will remain.
Jerry
SOURCE: Extremely low sound
had the same problem the hinge used in this model is causing this it get worn out quickly ,i had to replace it thrice within nine months......even pcb was replaced.now having problem with sys port ,i
Deborah I'll get someone to translate for you page 12 of the manual. You may also consider visiting www.Motorolacordless.us and ask if they could translate it though it appears to be a Mexican specific phone. Mark Motorola Mobility Support
