The battery needs to be inspected.Either battery voltage low or battery is weak and needs replacement or the Battery terminals are loose or dirty.Try cleaning them with contact cleaner then reconnect and see if the problem still exist.For more help.Go through Mercedes repair guide.Mercedes Benz Car Repair Guide?http://repairhelpcenter.blogspot.in/2012/03/mercedes-benz-car-repair-guide.html -----------This will help.Thanks.
it is telling you your left turn signal bulb is out. You have to replace the bulb in your left turn signal. Almost any typical drive through type of oil can Henry or those quicky oil changes places can do that for you, real cheap, If you don't want to mess with it. Hope this helps Mike
Need to go in to settings and select set current location. Some time if your turn power off and then turn it n, BUT while you turn it back on keep on button depressed while it's turning on for 15 seconds, this is way to manually reboot system, let me know please if Was helpful. Thanks mike
either battery is flat or its died a death on you ,yes i know the voltage may show 12v but the reserve amperage ??? it has none and it needs around 200 amps to turn over
This is a costly item. To buy the radio is about 450 dollars and then to have it installed is another ?. That is all the dealer is going to do is put in another one.
if the sound is like a click noise then it may be the solonoid on starter. if this fails it will not turn engine over. it just wont engage flywheel. if need be have it checked to see if the starter and or solonoid are bad.
If nothing is broken, check to see your dash light dimmer isn't turned all the way down. If you have automatic lights that turn on at dusk and you place something over the light sensor (usually on the dash board), the headlights will come on during the day and set the dash lights to the dimmer switch setting.
