Tip & How-To about Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045 Logo
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
