Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
A
Anonymous Posted on Feb 11, 2015
Show picture of where gas vent is on 55 husky chain saw
Eugene Rounds
Level 3:
  • Husqvarna Master 1,169 Answers
  • Posted on Feb 11, 2015
 Eugene Rounds
Husqvarna Master
Level 3:
Answers
1169
Questions
Helped
592801
Points
4432
Item 10 in the following is where your tank is.
Show picture of where gas vent is on 55 husky chai - 25414748-3ltgkmdacdwnz4x0o5uk2bdr-5-0.png
1helpful
My Echo CS 3400 chain saw has an air vent problem
Most handheld power tools have a tank vent that will hold some pressure, Don't quote me. But If I turn the saw sideways and the vent allowed fuel to drain out THIS WOULD CREATE A FIRE HAZARD. If the fuel is boiling when you open the fuel cap could this be a engine temperature problem? or low octane fuel.
Apr 07, 2014 • Garden
Where is the gas tank vent located on a 395 xp? Husky chain saw
The tank vent is on the top right hand corner ( as you stand behind the saw ) of the fuel tank, you should be able to see it between the crankcase and the tank, there will be a black pipe coming from it up to the carb area, it is pushed into the tank, you can buy it as an assembly 537338101.
Feb 23, 2013 • Garden
2answers
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
I need a bow blade to fit a 455 husqvarna
I make no guarantee of the applicability of this research. I recommend you contact "CheapChainsawParts.com" (or 1 (800) 438-0668) to verify this application.
Methodology to arrive at the bow part number "HQ-100"
An Oregon bar for a Husky 455 is mount/oiler configuration "095" ( the last part of any Oregon replacement bar).
A Oregon bar for a Husky 55 is also mount/oiler configuration "095".
You can check my Oregon research here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
This bow
http://www.cheapchainsawparts.com/cmp_HQ-100_part.html
is the replacement bow for a Husky 55; it should also fit a Husky 455. I make no affirmation there are no modifications required, applicability of this application, or even that it will fit.
Please reply below with what you found . TIA
Lou
4helpful
Husqvarna 372 xp gas tank not venting has a new gas cap did not work
I looked at a 2007 IPL, your saw has a separate fuel tank vent. Husky is terrible about providing a nomenclature and you may need help from your local Husky dealer to identify components.
Find your "Illustrated parts lists" here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
2helpful
2answers
Husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Husky 55 chainsaw
All chainsaws are air cooled. The problem is the cylinder head often sits underneath the gas tank. People fill their tanks with a mixture of gasoline and oil and often spill it or overfill the tank causing that oily mixture to coat the cylinder often. Then all the saw dust and dirt sticks to the oil and pretty soon the cooling fins on the cylinder head and all the parts surrounding it are coated with an oily dirty grime that keeps air from circulating around the cylinder head letting it cool normally. I'm not that familiar with a Husky but you need to be careful about other parts in the area, but you need to clean off the cylinder head so that it can get some cooling and quit heating up the gas in your tank. Usually there is a vent in the gas cap also and if it's plugged it will cause the gas tank to pressure up and force more gas than is necessary into the carburetor. Either clean the vent or buy a new gas cap.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
