Nintendo Wii Console Logo
A
Anonymous Posted on Feb 11, 2015
For Free Wii u Gamepad Codes - Nintendo Wii Console
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Mar 02, 2015
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532754
Points
2214
Although you did not specify a game, here is what I found on a good cheat site :http://www.supercheats.com/wiiu-cheats.htm
2helpful
Wii U power saver screen?
I think that the Wi U console that you have bought is broken and you will have to bu another Wii U console. Lukie Games and DK Oldies and East Starland Games and JJ games sells Wii U consoles.
Why does my wii u game pad get stuck sometimes
Reset the Wii U GamePad by performing the following:
Press the hold the power button until the Wii U GamePad powers off.
If the AC adapter is plugged into the Wii U GamePad, unplug it.Wait 30 seconds.
Power the Wii U GamePad back on and see if the issue has been resolved.
General system stability can be improved by applying the current system update. Try applying the latest system update and see if the issue has been resolved.
How to reset parental control for wiiu
While on the Wii U Menu, press the HOME Button.
Check that the Wii U console's date and time settings are correct. ...
From the Wii U Menu, select "Parental Controls."
Tap "I Forgot" or press the X Button.
Answer your secret question or tap "I Forgot." ...
An inquiry number will be displayed on the Wii U GamePad.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/1078/~/forgot-parental-controls-pin
Why does the Wii U displays an error code... when the Wii U is not turning on... even though is not defective???
That is a unique error. Only Nintendo will be able to help you on this. That code can means software/hardware issues. But Nintendo can go through the process of resolving it. They will most likely wish for you to send it in. But if it works with a reset then that sound be fine.
How do i get amazon prime on my wii system
FOR ORIGINAL NINTENDO WII CONSOLE
Make sure your Wii is connected to the Internet. Then, open the Wii Shop Channel and search 'amazon', and it should come up. You won't need any Wii Points to download it. Totally free, after a few moments the channel will be on your system menu. Start it up, log in, and enjoy!
FOR WII U CONSOLE
Enter the eShop via the orange shopping bag at the bottom of the GamePad screen. Search 'amazon', and the application should show up in the results. It's completely free, and after the download all you need to do is start it up and log in.
Hope I helped! Have a wonderful day.
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
I have cheap gamepad i was working properly and one day when i was playing it sudely stoped working and now when i connect my gamepad pc shows it as unknown device
The wiring may be frazzled. I bought my son two 'compatible' gamecube control pads so he could play his gamecube games on his Wii, but they got fried. So my new motto is to spend that little bit more if you want longevity.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
