You may have to high a water pressure. This may have been disguised in the past by the mains tap being partially closed (deliberately). The plumber will have opened the mains tap fuuly after repairing the leak. Alternatively you have water hammer caused by loose pipework. The plumber may have removed a pipe clip in order to repair the leak.
SOURCE: vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
SOURCE: I have an older Delta single handle shower scald
It sounds like it has mineral deposits in the hot water side. Try taking the internal valve parts completely out of the fixture and examine them. If there is any scaly (light grey) deposits, that would be the problem.
The solution is to soak all the parts in vinegar, which will dissolve the mineral deposits. It takes awhile to dissolve what has taken long to build up, so heat the vinegar, or put it all on a warm, not hot, surface to keep it more active.
I had this problem, and after cleaning it a couple of times with vinegar, I changed out the Delta to another brand. You could also use a water softening unit, which replace calcium and other metals with sodium, thus eliminating the mineral deposit problem.
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
