Just connected chrome cast and receiving message to disable AP isolation. not sure how to do this?
SOURCE: D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
SOURCE: DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
SOURCE: DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
SOURCE: Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
SOURCE: Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
