You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
What size is the TV?
There are different kinds.
Fixed mount - Fixes the TV flat to the wall
Tilt mount - Fixes the TV flat to the wall but you can adjust the angle.
Cantilever mount - Fixes to the wall but can be pulled away from the wall and put in any directions or angle.
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
There is no wall mount bracket for the VCS-10. It was not designed to be wall mounted. Your best solution is to mount a 22"x8" shelf to the wall 4-6" below the TV. Make sure it is mounted sturdy enough to support 10lbs.
I purchased my tv mount from Ultimate Electronics/ Las Vegas, NV. The name of company is Omni Mount, model: U2 Fixed. The phone number is 1-800-MOUNT IT. Good Luck.
