A
Anonymous Posted on Feb 11, 2015
Reset xerox c2255 btr (r7) counter
The printer shown replace r7, i bought r7 and follow to replace, but the instruction to reset r7 counter cannot be found on control panel, the message still persist, how...........
andrew_ha135
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 15, 2015
andrew_ha135
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
9506
Points
29
Code is 954-821
To enter diags and reset hold down right arror then left arrow, release both together the press online within 3 secs.
goto preventative, then HFSI. dont change anything else in this area as you can toast the machine.
1helpful
009-349 key to reset
There's no reset for that error, the error indicates that the 1st BTR did not reach the retract position. Try clean the 1st BTR Retract Sensor and look for damage. Also check the gears for breakage.
2answers
Xerox 7345 009 343 error code
Check out the Xerox.com website for more upto date information.
.Good luck.
How do i reset r6,r7,r8 on xerox 7435
R6-7: Go to consumable tab on your printer.
Select the R6 or R7, select reset counter.
R8: You're not able to reset it
Mar 12, 2013 • Cameras
Error code 9-343
hi, check the 2nd BTR, the sensor and check if the main motor runs normally.
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
1helpful
3answers
How do i reset the second bias transfer roller on a Xerox 3535?Thanks, chris [email protected]
You need a Xerox service laptop to communicate with the beast and reset it, that is what I was told by a Xerox Tech, Nasty I know but no other choice they got you.
8helpful
2answers
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
24helpful
2answers
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
9helpful
4answers
Error code 9-342 at start up / docucolor 12
That is a BTR contact failure. The Bias Transfer Roller is not making proper contact.
Most likely time for the BTR assembly to be replaced.
2answers
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
