Jiffy ice auger its starts but doesnt stay running
Sounds like the float is stuck.See if you can remove the float bowl.Once it's off try and separate the float from the carburetor.The float will be holding in a small needle,check it for free movement.They're pretty inexpensive and would be a good thing to replace.The float will crack,then fill up with fluid.Once full it will cease to function,opening and closing off the fuel flow.Then the needle will stick and you'll get little or no fuel.It's a real simple carb,they're less than $50 brand new if it sounds like too much to work on.Hope this has been some help?You do know this is posted under PC Desktops,right?
