Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
A
Anonymous Posted on Feb 10, 2015
Jacuzzi flush problem
Nothing! water sprays from under the float cup. very little comes through the fill tube.
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Jan 04, 2009
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Anonymous
  • 349 Answers
  • Posted on Jun 05, 2010
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
Anonymous
  • 349 Answers
  • Posted on Jun 10, 2010
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
Anonymous
  • 67 Answers
  • Posted on Aug 03, 2010
SOURCE: High pitch shrill when flushing
I had the same thing happen to my toilet. The quickest way to resolve the issue is to replace the fill valve.
geo5734036
George Hels
  • 528 Answers
  • Posted on Dec 01, 2010
SOURCE: Jacuzzi BK37959 White Era
Is there a good flow from the small feeder tube going into the center tube the flapper mounts to? It is possible your flush assembly has mineral deposits,rust,calcium,etc. build up and is not allowing sufficient flow through that tube to rinse the sides of the bowl. You could also Try dumping undiluted C L R (calcium,lime,rust) cleaner into that tube and allowing it to clear the passages. If the passages are blocked you will notice the water flooding back out of that central tube in the tank and may be able to use a small inspection mirror and a piece of baling wire to clear the exit ports around the rim of the bowl. You may also be able to clean the entire flush assembly by removing the water line from the bottom of the tank then removing the flush assembly and soaking it in C L R for a half hour - or, just replace the entire assembly. I hope this helps!!
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 • Home
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
5helpful
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Bowel cleaning
Check the ports under the rim and make sure they are not clogged. To do this you can use a nail or pin to clean them out.
Right under the rim of the bowl are these ports that allow the water to flow into bowl in a turning motion to aid in flushing and cleaning wall's of the bowl.
Inside the tank check the fill tube and make sure it is connected from the fill valve to the over flow tube. Also check the fill level in the tank and make sure water is up to the line on the fill tube about 5/8" from top of tube.
3helpful
2answers
Water level in bowl too low
Hello, W/D, toilet expert, here.
The tank has a water level line cast into the inside back of the tank. That's where your water level should ideally be. Now, there are a variety of water level controllers, so we'll hit on the major ones. But first, a little nomenclature, so you'll know what it isn't. If you remove the tank lid, you'll notice a tube in the middle that's open, and usually has a smaller tube inserted or attached to it. This is the overflow tube, and feeds water to the rim of the bowl. At the base of the overflow tube is the flapper, and it controls the majority of the flushing power. The flapper is operated by a chain connected to the flush lever. When the flapper is raised (flushed), the water level drops. On the left side of the tank is the water fill valve, The water coming from the house via the tubing under the tank goes into this valve assembly. Part of this assembly is the all important float.
Older ones have the float at the end of an arm, As the water level falls, the float falls and operates the water inlet valve at the other end of the float, on the water fill valve. As the level rises in the tank, the float rises with the level and shuts off the water when it gets to it's pre-set level. This type is adjusted by positioning the float either by the screw adjustments on each end of the float arm, or sometimes by bending the float arm.
The newer types have the float either built in, or the float surrounds the fill valve. The one that surrounds the fill valve looks like a very fat donut and is very similar to the older float arm type, just more compact. The water level is set by adjusting the linkage between the float and the water valve at the top of the water control valve.
The newer newer type has all of the floating mechanism built in. But cleverly, there is an external adjustment for raising and lowering the water level. On the side of the tube, there are slots and raised dots on the lower tube. The upper tube has slots on the inside of it. There is a white locking tab between the two tubes. Here's how this one works: (Turn your water off first for adjusting this type). The tube is in two parts, an upper and lower tube. They are held in place by the locking tab, and by the slots cast into the two tubes (they intermesh) To adjust this type, you have to raise the lower portion of the locking tab to raise it off of the locking dots, and than revove it. Then, you push down slightly and twist the upper section to unlock it. Set the level higher or lower, twist the two parts back together, and reinsert the locking tab. The aim is to set the water level at the level mark on the tank. This type can be tricky; you'd do best to turn the water off to adjust this type, and turn it back on once you have locked it back in place.
Best regards, W/D
Our American Standard toilet flushes ok but fills back up real slow. Very little water comes out of the hose that goes in to that tube. Can you help Thanks Howard
Okay Howard. It seems that the fill or float valve inside the toilet tank needs to be replaced. If you have a pair of channel locks / large pliers and some patience, you can do this yourself and save $ on a service call. This Solution is providing that you have good water pressure everywhere else in the house. First turn off the water on the supply line going to the tank. Flush the toilet (with the water off) to empty the tank. Take a towel / sponge / or wet vac to remove any remaining water. Remove the nut on the underside of the tank that holds the float / water supply to the tank. Now that you have the water float removed you can go to your local hardware store / Home Depot / or Plumbing Supplies Store and get a new fill valve. There are different kinds but they all do the same thing, fill your tank. I use a Fluid Master, But you may have to use one like you have. The Store will assist you. They are only about $10 - $15 Bucks or so.......Install the new float according to directions.....It is pretty simple. Insert your new float stem into the hole with the proper rubber washers and tighten carefully for a good seal. Insert the new black hose into the overflow tube and you are in business. You will have to adjust the water level to about a 1/4 Inch below the overflow tube for a good flush!!! I hope this helps you with the slow tank fill.............Joe
62helpful
4answers
Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Nov 28, 2008 • Home
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
