A
ALICE CHAN Posted on Feb 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOT TO REPLACE THE LANIER LD 122 GREEN TONER LOCK LEVER/CAM HANDLE
ANY SPECIAL TOOL NEEDED TO REPLACE THE GREEN TONER LOCK LEVER/CAM HANDLE
quennie732
Level 2:
  • Lanier Expert 422 Answers
  • Posted on Feb 18, 2015
quennie732
Lanier Expert
Level 2:
Answers
422
Questions
0
Helped
236045
Points
775
Easier to replace hopper P/N B0273501, not too pricey. -Carl
1 Related Answer
Anonymous
  • 26 Answers
  • Posted on May 20, 2010
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
I need to replace the green toner lock lever/cam handle on my Ricoh copier. How do you do this?
First buy handle ansd slide holder. What's has happen toner has gotten behind it that's way handle broke or won't close properly. Second there is another lever you push to slide hopper all the way out. Keep it level or you will spill toner every where. Make sure you have a towel or somethings for toner spill to put under toner hopper. Second remove metal bar and then slightly pull up tabs could be three of them be careful is a spring behind it. It will push inter cover out and can spray toner everywhere if you just let it pop out. Once this is done now can remove green handle. And reverse procure
Lanier ld 220 won't clear replace toner after i changed it
Very Common problem on that model Problem with the toner hopper assembly. Sometimes the green handle metal pin is out of position. The plastic green handles break a lot also.
1helpful
Ink box full
1.Turn off the printer power switch. Press the front cover release button and then open the front cover.
2.Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
3.Release the gray lock lever (1) that is on the left side of the printer. Pull the drum unit completely out of the printer.
4.Hold the green parts of the belt unit with both hands and lift the belt unit up, then pull it out.
5.Remove the waste toner box from the printer using the green handle.
6.Unpack the new waste toner and put the new waste toner box in the printer using the green handle.
7.Put the belt unit back in the printer. Match the mark on the belt unit to the mark on the printer. Push down on the green area of the belt unit to lock it in place.
8.Put the drum unit back in the printer as follows.
Make sure that the gray lock lever (1) is in the up position and put the drum unit in the printer. Push down the gray lock lever (1).
Push the drum unit in until it stops.
9.Close the front cover. And turn on the printer power switch.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Sc 544 lanier ld 122
Lanier ld 228c says printing will begin after warm up, but it never warms up. Tech says hard drives are bad and need replaced. he put new ones in but still did not correct problem.
Check and measurement the fuser unit components(heater lamp,thermistors and thermalswitch) and check the toner quantity in the copier.If not toner the machine not start to working.
1helpful
2answers
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
2helpful
Savin Copier 3515
Hmmm.. try this
  1. Open the Front Cover
  2. Lift the large green handle up to its full extent
  3. Press and hold down the green lever to the left of the green handle
  4. Use the green handle to pull out the Toner Tray slightly then release the green lever
  5. Pull out the Toner Tray to its full extent
  6. Push the toner bottle towards the front of the black housing where the green lever is located
  7. Push the green lever down while continuing to hold the toner bottle towards it.
  8. Slide the whole assembly back into the device until it clicks into place
  9. Close the Front Cover
  10. The device should now attempt to Add Toner
  11. If the Add Toner indicator light does not go out repeat
2answers
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
