Everything I can
SOURCE: Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
SOURCE: Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
SOURCE: flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
SOURCE: configure the saeco coffee vending machine type AD 7P PLUS
Hope this is what you're after
http://pdf.archiexpo.com/pdf/saeco/7p-plus-11410-3425.html
SOURCE: My saeco primea touch plus cappucino grinds coffebeans, but no co
At the extreme top left of the brew group, above the last filter (mentioned in another response), there is a spring loaded tip that I assume is pushed open by the pressure of the brewed coffee, before the coffee streams to the dispenser nozzles. When I dis-assembled this (2 philips screws) the tip seemed very sticky (slightly jammed?). I pushed the ip several times against a hard surface and freed it up. Re-assembled everything (plus cleaned the last fliter). Works fine again.
