Matty Posted on Feb 10, 2015
I have just bought a samsung soundbar hw h355 and I'm trying to connect it up to my toshiba tv, via the aux cable but I get no sound from it via the tv link. I works when I link my phone up via Bluetooth. I've tried two different ports for connection and neither provided any sound has any one got any ideas what I could do?
Brandon M.
Level 1:
  • Contributor 34 Answers
  • Posted on Feb 11, 2015
 Brandon M.
Contributor
Level 1:
Answers
34
Questions
Helped
25981
Points
60
Please get a optical cable and run it from TV to soundbar for best sound. If you are using aux input on sound bar that will work but it is analog sound. TV needs to have mini audio out or red/white output on it maybe labeled audio out
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
2 Related Answers
Leon Kedward-Jones
  • 61 Answers
  • Posted on Jun 24, 2014
SOURCE: Trying to connect samsung soundbar to Technika tv.
Hi probably a silly comment - have you connected to the AV in or Out sockets on the TV? Worth checking? also do you need to select an audio profile on your TV in order to divert from the internal speakers. Worth looking at your sound preferences on your TV
Romz Rodriguez
  • 75 Answers
  • Posted on Dec 30, 2014
SOURCE: How do i get soundbar to work with my tv
either you use hdmi cable or optical cable
2answers
Got an ONN TV and an ONN soundbar. Hooked up via RCA cable. TV audio in PCM mode. Soundbar in AUX mode. Can't get any sound from soundbar. What have I missed?
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
How do I connect a Goodmans sound bar to my Toshiba Regza tv as the manual says connect via Aux
hook the soundbar to your axillary output or audio output or speaker output
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
1helpful
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
2answers
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Cannot figure out how to connect my new sound bar to my older TV
Use a high speed HDMI cable form the TV to the sound bar. HDMI cables carry sound as well as picture signals. Refer to your TV's user manual http://www.hdtvsolutions.com/pdf/52527-62528.pdf
and the Samsung product support page http://www.samsung.com/us/support/owners/product/HW-F450/ZA for assistance
How do I connect my LG 32LD350 to a samsung HW-E350 sound bar? My tv does not have audio out jacks.
Sorry but you cannot do this with this tv.. You need hdmi 1.4 support and you only have 1.3 the only way i have heard of it being done is through the headphone socket to a 3.5 jack to the aux socket on the soundbar.... johnB
I have recently purchased the Samsung hwd450 sound bar. After about a month of use, the sound has begun cutting out when watching tv. Changing the input or powering off corrects the problem. The cable box...
Yep... the "formula" is generally this:
"IF it's electronic, MOST failures happen in the first 30 days".
THAT
is written in stone somewhere on a tomb wall.
But THIS MAY be your answer:
"I too, put up with the "Audio Hiccups" for months and after trying nearly everything, including replacing all my connections and even the sound bar itself, I realized that it had to be something in the software or settings. So ... I went into Settings/Audio and changed the Digital Audio Output from "Auto" to "PCM" ... it worked!!! I haven't had any problems with the audio since; hope this helps you, my friend."
Here is a great insightful Link for you:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?from_osc=&homeid=464999&idx=546561&modelcode=HW-H750/ZA&modelname=HW-H750&
bar-ay53xupi2pin52cfytgihs5s-2-0.jpg ANTHONY
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
