I am moving and would like to partially disassemble the elliptical.
SOURCE: Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
SOURCE: Please help for how to
The best way is to detach the two upright posts that hold up the console from the frame. You will also have to unplug the wiring harness inside one of those uprights. Once you have done that, you can move the machine in just two pieces. If you have any questions, feel free to contact our Customer Service Department @ [email protected]
Chase
NordicTrack Social Media
SOURCE: My NordicTrack E5 vi Elliptical is squeaking really bad. How do I fix this problem?
go to :http://www.ehow.com/how_4681374_fix-elliptical-machine.html
God bless you
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
SOURCE: nordictrack cx1055 vibration problems
see the next steps: Lube and use the logically. God bless you
Inspect the leveling feet on the rear stabilizer of the
elliptical. Note if both sides are not flush to the floor. Unplug the
machine if they are not flush to the floor.
