A
Anonymous Posted on Feb 10, 2015
Can the SP 204 SF scan to pdf?
All the scan setting relate to pictures not pdf
quennie732
Level 2:
  • Lanier Expert 422 Answers
  • Posted on Feb 18, 2015
quennie732
Lanier Expert
Level 2:
Answers
422
Questions
0
Helped
235963
Points
775
Yes to PDF or TIFF select in scanner fetures under user tools... -Carl
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 10, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
254936
Points
4299
Here's a workaround while you're searching.
Download CutePDF or PDF redirect and install.
Now after you scan to picture, copy and paste to a document and print or just print the image and send to the new 'printer' to PDF thingee and voila ...
PDF reDirect The free PDF Creator alternative to pdf995 cutepdf and freepdf
I have a new laptop with Windows 8.1 (lucky me). I can't seem to get my Brother MFC 7860 DW to preform its normal scanning in pdf format.
you can try this solution : first scan to picture file and after convert it to a pdf file with a pdf printer like this one : http://www.bullzip.com/products/pdf/info.php
or try to find an update to the software (for the printer) at brother.com here :
http://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=mfc7860dw_all
hope it helps..... if not then return here ...
3helpful
Risoh aficio sp 3510 sf
my printer richo sf 3510 sir. my problem replace required soon print cartridge show on the display
6helpful
Ricoh aficio sp-1100 sf toner chip reset problem
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
How to scan in pdf format using the Ricoh Aficio SP C221SF
In Acrobat proffesional: File/ Create pdf file/From Scanner
Receiver shuts off intermittently, when you turn it back on it says "check SF wires". What are SF wires?
It's "check SP wires". It means (do I have to say it?) Check the Speaker Wires for short circuits.
After powercut I cannot set the answering mashine and fax
I have a manual.
My scanner is faulty though and I'll be looking at buying a new one today. I will then see if I can scan the manual to pdf for you.
Please let me know how I can contact you.
Regards,
Gary
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
