Canon PowerShot A480 Digital Camera Logo
A
Anonymous Posted on Feb 10, 2015
Unfreezedoes not function goes diectly to viewing
Batteries
2answers
Blocked washer jets
Find hose that goes from pump to hood ,should be a connector inline somewhere. Disconnect hose and use air nozzle to blow back through jets
1helpful
2answers
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
2helpful
2answers
Im pressing the buttom that everyone is saying is the inverse key but it is saying error. i really need help with this.
It is much more enlightning to tell us what you want to do rather than talk about something that does not exist. And one thing that does not mean anything is that ellusive INVERSE key that everyone and his dog is looking for.
The additive inverse of a number a is its opposite (-a). The key to use is the change key (-).
The multiplicative inverse of non-zero number a is its reciprocal 1/a
The inverse of the natural log (LN) function is the EXPONENTIAL function e^(x). On most calculators if one function is accessed diectly (the marking is on the key), its inverse is accessed by pressing [SHIF] (Casio, or [2nd] (TI) or [2ndF] (Sharp).
The inverse of the function raise 10 to a power [10^x] is [LOG]
Similarly, the inverse of the sine function SIN is the arcsine [sin^-1]. To access the latter, it you press [2nd][SIN]. The same is true for arcosine [2nd][COS], and arctangent [2nd][TAN]
The inverse of the square functions [x^2] is the square root function [2nd][x^2]
Inverse of x^3 is cubic root
This is just a quick overview.
1helpful
I have 3 power wires on my Jensen MCD5080 marine am/fm/cd, a +12dc switched (acc)red wire , dimmer orange wire and a +12v dc battery (constant batteryemory yellow wire) do i hook them all to the same power...
The yellow wire (constant) is for functions such as clocks, retaining fm stations, etc. The red wire (DC power) is what runs the unit. You said this is going on a golf cart right? But you say you don't want switches and don't want it to drain the battery during storage. Well, you can't have the best of both worlds. If you don't like the visual of a switch in the open, at least put one close to the battery under the seat. That way you can switch it off in storage. The switch would go to the red wire. You might even think about switching the orange wire if you expect to keep it in long term storage. the dimmer wire usually hooks to interior light controls. Like when you turn your lights on to drive at night, the radio won't be so bright inside, but in the day time, it will be. This is not a necessity. Happy wiring
3helpful
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
How do i find a manual for diect 6.0 digital in english
Not sure what your model number is but you can find a user manual here for a 28851FE3 model. It might work for you. - http://pdf.smithgear.com/28851FE3_IB.pdf
I want to wire my new Garmin 550 to my 2008 softail delux. where do I hook it up to
Do you plan on hard wireing the power cord? This would be personal preferance, if it was mine I would splice/tap into a ignition/hot wire so when you turn off the bike power turns off to the unit. That way it would not be a constant drain to the battery. There are some hot wires between the tank by the frame just use a test light and find one that goes on and off with the key. There are also many variations of connectors to use. If you would not forget go diectly to the Battery but be sure to add a fuse to the wire to protect the GPS.
2answers
My samsung l730 digital camera doesnt stay on when switched on Just shows blue light and goes off again
Take battery out and clean terminals on Battery and in Camera
[An eraer on end of pencil is good for this]
Make sure battery is fully charged.
or
Take to a dealer and ask for a fresh battery to try of it works replace the battery.
If none of this works and the camera is over 1 year old [out of warranty]
replace the camera.
Nov 10, 2008 • Cameras
Display turns itself off
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
