I've changed rings to 6, changed the forward rings to 10. Don't know what else to do.I've changed rings to 6, changed the forward rings to 10. Don't know what else to do.
has your system changed since you were last into admin programming (feature**23646, password is usually 23646 also)?has your system changed since you were last into admin programming (feature**23646, password is usually 23646 also)?
You can't post conmments that contain an email address.
Changed number of rings to 6, changed forward answer delay to 10. Don't know what else to do.Changed number of rings to 6, changed forward answer delay to 10. Don't know what else to do.
GO TO CONTROL PANEL - ADD REMOVE USER ACC.- SELECT THE ACC. YOU WISH TO DELETE. KEEP IN MIND IF YOUR ACC. IS A ADMINISTRATOR YOU WILL NOT BE ABLE TO DELETE IT. IN THAT CASE MAKE A NEW ADMIN. ACC. AND DELETE THE OLD UNWANTED ACCOUNT. REGARDS. PLZ. RATE THIS
If you want to access the Router Settings Page of your Linksys WAP4400N just open a Browser then enter 192.168.1.245 and the Default Username is admin and the Password is admin
Unfortunally there is nothing you can do. If you have an admin password, you could use that and reset your password an ID. If not, you will need to reinstall the os to gain access.
ssid is the name of your acces point your better of putting search for an acces click your acces point and type admin as your wep key it may work use it if your close enough to your computer
Since you clicked on System, you will have to contact your IT/network admin, to grant your rights back to this folder, and explain you accidentally hit system to deny access
