Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
- SSID
- SSID Broadcast
- Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to
No Encryption, this means that the wireless security on the gateway is disabled.
64 Bit Encryption or
128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for
