If your Ecco TV 32 D-LED is stuck in USB mode and the source button is not working, and you don't have a remote, there are a few things you can try to resolve the issue:
Power cycle the TV: Unplug the TV from the power source and leave it unplugged for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the TV and resolve minor software glitches.
Try using the buttons on the TV: Although you mentioned that the source button is not working, try pressing other buttons on the TV itself, such as the menu or volume buttons. Some TVs have different combinations of buttons that can act as a substitute for the source button. Refer to your TV's user manual if you're unsure about the button combinations.
Check for a physical source button: Look closely at the TV's physical buttons to see if there is a dedicated source button or a button with an icon indicating input selection. Pressing this button should allow you to cycle through different input sources, including USB mode.
Borrow a universal remote: If you don't have the original remote for your TV, try borrowing a universal remote from a friend or neighbor. Universal remotes can often be programmed to work with different TV models. Check the remote's instructions or manual on how to program it for your TV brand and model.
Contact the manufacturer: If none of the above steps work, it's recommended to reach out to the manufacturer's customer support. They can provide you with specific information tailored to your TV model and help troubleshoot the issue further.
Please remove all unnecessary attachment from your tv and then attempt to use your remote again. If the remote does not work properly, then you can move on to running a power cycle (ie unplug the tv for 30 seconds before plugging the power back in).
Then you can test the remote again. Otherwise, the tv might need a factory reset in order to overcome the issue at hand.'
If your Bruhm 32-inch curved TV is stuck in USB mode and you don't have a remote, there are a few different things you can try:
Try using the buttons on the TV itself: Some TVs have buttons on the side or bottom of the screen that can be used to navigate menus and settings. Look for buttons labeled "menu," "input," or "source" and see if you can use them to switch to a different input or exit USB mode.
Unplug the TV: Unplug the TV from the wall outlet for a few minutes, then plug it back in and turn it on. This can sometimes reset the TV and clear any issues with the USB mode.
Obtain a replacement remote: If you don't have a remote, you may need to purchase a replacement. Check with the manufacturer or a retailer that sells Bruhm TVs to find a compatible remote.
Use a universal remote: If you have a universal remote, you may be able to program it to work with your Bruhm TV. Consult the manual for your universal remote or contact the manufacturer for assistance in programming the remote.
If none of these steps work, you may need to contact Bruhm customer support for further assistance.
I would suggest you take that remote back. I got a cheap 8 dollar GE remote from Dollar General for 8 bucks and all that is required to program it is for the TV to be on. I've never heard of a universal remote having to be in TV mode as that would defeat the purpose.
