1. Turn OFF the main power switch. 2.Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears 3.Touch [Trouble Reset]. 4.Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, wait 10 seconds and fire the machine back up, this should reset the service code and with any luck the machine will run!
Solution ID TAUS0800276EN* Solution Usage 1 Description
C-3102 (C3102). Solution
CAUSE: Fusing roller failure to turn due to a broken Fuser Rotation Sensor Holder.
SOLUTION: Replace Broken Fuser Rotation Sensor Holder (p/n A00J 7323 01).
The code indicates that the fuser is not turning for whatever reason.............. Do the following if it resets the code great, if it comes back it's probably the sensor on the fuser that detects rotation I think its PS-47. They have had problems with the mounting plate but at any rate at that point it would be time to call your servicing entity.
The code indicates that the fuser is not turning for whatever reason...... Do the following if it resets the code great, if it comes back it's probably the sensor on the fuser that detects rotation. They have had problems with the mounting plate but at any rate at that point it would be time to call your servicing company. Here is the reset procedure: 1.
Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the Trouble reset appears 3.
I found a website for the remote you need. I need one too. Go to remotes.com and put your model number of DAV 3102 in the space. It will show you the original remote and a replacemet you can use. Kind of expensive but worth it to me.
