Check mobile phone settings - look for mobile hot spot.This is a special feature where the mobile uses mobile data (be careful have a data plan on mobile otherwise costly ) and then the mobile phone also creates a wi fi network that you can hook into on the win 8.1 laptop. HOWEVER THE MOBILE WILL NEED TO BE POWERED ! either via the p.c's usb port or via a charger pack as this mode uses up a lot of mobile phone battery
SOURCE: Bluetooth problem
if you have a built in bluetooth connection, then what may be happening is that the pc is turning it off in a power saving state if not being used, the same thing sometimes happens when a bluetooth dongle is conected to a usb port, you have to unplug and plug it in again to get it to connect as the pc doesnt recognise it. Try turning it off by the function button then on again, or check your notebook settings in the power options, as they are able to turn both bluetooth and wireless connections off to save power.
