Changed battery twice
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
SOURCE: viper remote stopped working 791xv
I have the same remote and it comes disconnected in the battery section from the battery hitting it and then the commands and speaker stop working
as shown here
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
SOURCE: I have a viper starter
Your alarm might be in a timed-start mode or temperature start mode. It should be able to be reprogrammed or reset to function normally again but you'll have to consult the installation manual, which might call for a visit to your local alarm install shop.
