Question about Razor E100 Electric Scooter
Razor Scooter ground fOrce go cart wont go
Battery lights up, throttle says full power, but when you push the throttle the cart tries to go, like the wheel moves 1/4 inch and then stops. If I lift the cart up, it will do the same thing, move wheel a drop and then stop. what do I need to replace or do?
    Habit-Forming:
    Scholar:
  • 89 Answers
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Posted on Feb 09, 2015
SOURCE:
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
Razor e100 dead
Check the battery and charger with a multimeter and make sure that its putting out the required voltage or more, also inspect the batteries for bulging
Jun 07, 2012 | Razor E100 Electric Scooter
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Jan 29, 2011 | Razor 300001-SL Ground Force Go Kart
I have a razor e200. Nice physical condition. Garbage picked. Light on throttle lights up next to the 24V label. No power when throttle is open. No engine noise. power switch is on. reset button is...
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
Jul 31, 2010 | Razor E200/300 Electric Scooter Battery
Full battery power but still wont go
Check the brake leveler at the back of the scooter. If you can push the scooter this means its in free wheel. Move the brake then switch the scooter on and try.
May 18, 2010 | Health & Beauty
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
Razor E100 Electric Scooter Logo
184 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
