Dishwashers Logo
k
karissa Posted on Feb 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishlex DX203SX Dishwasher door wont close
This model dishwasher was already in the house that im renting. Seemed to be no more than two to three years old and in excellent condition,until tonight,when the washing cycle finished i went to open the door and it wouldnt open. It was so hard to open, it wouldnt unlock. Usually when a cycle is finished it is easy to open but not this time. My husband reset the control panel and managed to get the door open. But now it wont shut. The door wont click in. This is the first time this has happened since we have lived in this house. Never had a problem been working so good up until now. We treat the dishwasher with great care. Can someone please tell me why the door wont close and how come it was so hard to open after the cycle finished?
paul srigley
Level 2:
Sergeant:
  • Expert 337 Answers
  • Posted on Feb 07, 2015
paul srigley
Expert
Level 2:
Sergeant:
Answers
337
Questions
8
Helped
60458
Points
987
Check the lock maybe it flipped shut lock maybe getting stiff from steam?
How to replace the bottom door seal on a Electrolux Dishlex dishwasher DX303WK
How to replace the bottom door seal on an Electrolux Dishlex dishwasher DX303WK.
To Note: Before you begin, make sure you have the correct door seal for your dishwasher model. Before beginning any repairs, switch off the dishwasher and unhook it from the power source.
Materials Needed:
  • New door seal compatible with Electrolux Dishlex DX303WK
  • Screwdriver
  • Pliers
  • Clean cloth
Step 1: Remove the Old Door Seal
  • Open the dishwasher door and locate the existing door seal around the bottom edge of the tub.
  • Gently peel back the old door seal from the edge of the tub. It should be secured with a rubber gasket or clips.
  • Use a screwdriver or pliers, if necessary, to remove any retaining clips or fasteners holding the old seal in place.
Step 2: Clean the Area
  • Once the old door seal is removed, clean the area around the edge of the tub thoroughly. Use a clean cloth to remove any dirt, debris, or residue.
Step 3: Install the New Door Seal
  • Take the new door seal and align it around the edge of the dishwasher tub, making sure it sits properly in place.
  • If your dishwasher has retaining clips or fasteners, use them to secure the new door seal in place. Alternatively, press the seal firmly to ensure it adheres to the tub securely.
Step 4: Test the Door
  • After installing the new door seal, close the dishwasher door gently.
  • Check for any obstructions or misalignment of the seal by running your fingers along the entire perimeter of the door. The seal should be evenly and securely in place.
Step 5: Reconnect and test the power.
Connect the dishwasher to the power source after ensuring that the new door seal is correctly placed.
Run a brief cycle or just check for leaks while the dishwasher is running normally.
If you run into any problems or difficulties throughout the replacement procedure, review the dishwasher's user manual or call Electrolux customer service for assistance. Additionally, if you are unsure about replacing the dishwasher yourself, consider hiring a professional dishwasher repair service.
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 • Dishwashers
you did not giver manufacturer, model and year, it is not possible therefore to give detailed info what to do - for future references - do provide these "little" details, telepathy is overrated and usually do not work...
from your description can be several causes of that, one of them is motherboard fault, another will be actuator and third can be mechanical fault within lock or with hinge... make your pick...
Feb 07, 2015 • Dishwashers
1helpful
2answers
Why door will not latch close on 103 dishlex dishwasher ?
Check whether the dishes are touching the door before closing the door..Or the spring mechanism of the latch is damaged
4helpful
2answers
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
13helpful
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
4helpful
2answers
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 • Dishwashers
3helpful
4answers
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
Bought a house with a Dishlex Supreme Deluxe Dishwasher already installed. It's an older model 8574 and we have no manual. Is it possible to get one somewhere?
Not sure if a manual would still be available but I can tell you that the Dishlex washer was made by Vulcan / Electrolux and was originally sold in Australia. You may want to check eBay Australia or some other online resources from down under! G’day mate!
Apr 01, 2008 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
