Computers & Internet Logo
P
PAULINE WAKEFIELD Posted on Feb 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHERE IS THE WPS BUTTON ON A MG5650 PRINTER, TRYING TO SET UP THE PRINTER AS WIRELESS
FOLLOWING THE SET UP INSTRUCTIONS, IT SAYS NOW PRESS THE WPS BUTTON, GRRRR WHERE IS IT
Jack Felton
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 90 Answers
  • Posted on Feb 08, 2015
Jack Felton
Expert
Level 2:
New Friend:
Night Owl:
Answers
90
Questions
0
Helped
25811
Points
212
The WPS button is on most wireless routers.On the printer go to tools and wilan setup and hit ok after you push the WPS button on the router
I am trying to hook up my canon mx472 to wireless (shaw internet) and it won't ask for the password. Therefore...no connection.
If the router/modem has WPS:
WPS Connection Method
  1. Make sure that the printer is turned on. Press & hold the [Wi-Fi] button on the top of the printer until the alarm lamp flashes once.
  2. Make sure that the lamp next to this button starts to flash blue and then go to your access point and press the [WPS] button within 2 minutes.
If your router does not have a clearly marked 'WPS' button, please use the CD with your computer to perform the standard wireless installation.
Where to find wps pin on canon mx494 printer
Hi Mbali, PIXMA MX494 Wireless Connection SetupSome access points (sometimes referred to as routers or hubs) feature an automatic connection button labelled "WPS" which stands for Wi-Fi Protected Setup.This allows permitted devices such as your PIXMA MX494 to connect to your network without needing to enter a password and it enables a quick and easy method of connecting your devices.This method is by far the easiest way of connecting your PIXMA MX494 so if your access point has a WPS button please select the 'WPS Connection Method' tab below for instructions on connecting using this method.If your router does not support WPS we have provided alternative instructions to get your PIXMA MX494 connected so please select the 'Standard Connection Method' tab below.Back to topWPS Connection Method Standard Connection Method Restore to Factory SettingWPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.Press the [Setup] button (B) on the printer. Use the arrow buttons (C) to select [Device settings] and press the [OK] button. Use the arrow buttons (C) to select [Wireless LAN setup] and press the [OK] button. The printer will now automatically search for access points supporting the WPS feature. The following message will be displayed on the printer's screen "Press WPS button of the wireless router about 5 sec. and press [OK] on this printer" Press and hold the [WPS] button on your access point for approximately 5 seconds, then release. For exact instructions on starting WPS on your access point, please refer to its user guide. Press the [OK] button on the printer within 2 minutes. Once connected, the following screen will appear. Press the [OK] button to complete the setup.
Thanks
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
Where is the WPS button on a netgear wireless router?
Not all routers have such a button.
Follow the instructions that came with the printer to "manually" select your wireless network, and to enter the password for your network.
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
1helpful
Can't connect to wireless network from canon mp499
Steps to Connect Canon MP499 to Wireless Network:
1. Check Wireless Network Settings:
Make sure your wireless network is operational and that you have the correct network name (SSID) and password.
Ensure that your Canon MP499 is within the range of your wireless router.
2. Printer Display:
On the printer's control panel, navigate to the setup menu. Look for a wireless setup option.
3. Run the Wireless Setup Wizard:
Initiate the wireless setup process on the printer. This often involves navigating to the "Wireless LAN Setup" or a similar option.
Select the option to connect to your wireless network.
4. Enter Wi-Fi Credentials:
When prompted, enter your Wi-Fi network name (SSID) and password. Ensure that you enter the correct information.
5. WPS (Wi-Fi Protected Setup):
If your router supports WPS, you can use this method for easy connection.
Press the WPS button on your router.
On the printer, select the WPS option and follow the on-screen instructions.
Greetings,
Antonios
5helpful
I am trying to set up my hp printer and I am trying to find the wps button on my 2wire router that the set screen is telling me to press. But I don't see one on it. Does 2wire support WPS, what ever...
Hello pbufordjr,
WPS stand for Wi-Fi Protected Set-up . According yo Wikipedia "The goal of the WPS protocol is to simplify the process of configuring security on wireless network, If your 2Wire router is equiped with that function it would be the BIG button on the bottom front of your router Look at this advertisement from 2Wire http://2wire.com/movies/pages/112.swf
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Grand Canyon Tech
Grand Canyon Tech
