Nokia C203 Logo
a
amritparkash Posted on Feb 07, 2015
Which screw driver is used to open c203
I try to open but doesn't open I need help how to open this and which screw driver is used
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
Hey! i forgot my security code for nokia c2-03 touch n type phone plz tell me how can i ulock my phone without any cost??
Hello Unless you changed the code, the default code should 12345 if it doesn't works there is a way to generate the current code but I'm not sure C2-03 is supported in this software or not.But at least you can try.How to Generate Your Phone Security code..Only for Nokia bb5.Otherwise you should visit nearest mobile repairing shop.Thanks for visiting fixya
Aug 24, 2012 • Nokia C203
5helpful
2answers
Nokia c203 driver free download
what driver ?? i didn't get you.
Dec 02, 2011 • Nokia C203
I got an error code 2556 on my c203.please help
Very very common issue... did you clear it yet?? if not to clear it open and close frount door. then to fix issue change toner.... if that doesnt do it try running something with lots of yellow on it... the code means there is too much yellow toner in the image unit... if that wont work then replace yellow image unit.OH you may want to clean the belt sencors too its super easy i can help if needed
I have bought a image transfer belt. I need to know how to access area where belt is located. Do I need to be careful in handling new belt
open right door (the door used to remove jam. there are 2 silver levers that have screws holding them down just under the fuser unit. remove the screws and that will release the belt. it wil slide out easily . then replace it. unfortuneatley you did not have to replace it unless it was dammaged... there is a small pico fuse in it that you can replace for like 2 dollars that will reset the counter... if you have more questions drop me a line
How do I print index cards through my bizhub C203?
use bypass tray, you must use thick 3 or thick 4 and the size needs to be close to the size of index, the tray settings need to be set for thickness and size and color then the same has to be set in the driver in computer also, when you go to print hit properties and change the tray to bypass and thick 3 or thick 4 and then the same size you selected in the copier and it should work. if by chance it asks you load paper in bypass after you hit print then it didnt get setup correct. check to see if you got the driver saying the same as the copier tray. ask if you need help
What software do i need to scan through a PC?
GO THOUGH WEB BROWSER ONLY THING YOU HAVE TO DO SET UP IP ADDRESS, DOWNLOAD DRIVER FROM KONICA/MINOLTA FOR BIZHUB C203 THEN WEB BROWSE TO SET UP SCANNER SOFTWARE ALREADY THERE.
1helpful
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
2helpful
Minolta c203 service menu
They extended the life of the image unit. They did not reduce the amount color in the print. Once they extended the life, the image unit will go until its copy qualilty will become completly destroyed. You will have to replace the image unit, sooner or later.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
