Washing Machines Logo
K
Kim Shoesmith Posted on Feb 07, 2015
Our AEG front loader doesn't finish the cycle. It stops during the rinse cycle and also on the spin cycle. What do I do??
Nothing. Initially it just would stop once and then I'd press the stop/pause button again and it would finish. However, then it stopped twice, and now it stops 3-6 times.
1helpful
My Midea front loader won't spin. HELP!
There are a few potential causes for your Midea front loader washing machine not spinning. Some possible reasons include:
  • Overloading: If the machine is overfilled with clothes, it may not be able to spin properly. Try removing some of the clothes and running the spin cycle again.
  • Belt problem: The belt that connects the motor to the drum may be loose or damaged, preventing the drum from spinning.
  • Drainage issue: If the machine is not draining properly, the spin cycle may not be able to begin. Check to make sure the drain hose is not clogged and that the pump is functioning properly.
  • Control Board problem: The control board is responsible for controlling the machine's functions. If it is malfunctioning, it may prevent the machine from spinning.
  • Lid switch: The lid switch is responsible for detecting if the lid is open or closed. If the lid switch is faulty, the machine may not spin.
It's best to check the owner's manual for troubleshooting steps specific to your washing machine, or contact the manufacturer for further assistance. If the problem persists, it is advisable to get it checked by a professional technician.
Why is it that my LG machine shakes violently while it's rinsing? Is it supposed to be like that please?
Question 2 also edited for clarity, 'LG' not 'lg'.
No model details again.
Surely not during 'Rinse' cycle? That just adds water and gently tumbles to get the soap out and complete the washing by further agitating the clothes. You must mean during spinning and much depends on if it is a front loader, or a top loader. For both, machine not level front to back and left to right and / or not sitting firmly on all 4 feet.
Top loader, bulky load unevenly loaded.
Front loader, single bulky item causing an uneven load.
Hello, I have an AEG front load washing machine. It appears to be leaking water during the spin cycle as it is dripping off the bottom bolt that secures the 2 halves of the tub. Additionally on one side...
The drying cycle uses a very small flow of water all the time it's drying. When it's washing it uses a large flow of water initially and for each rinse.
If the problem's only when when drying then the one pipe it's using only for drying may be leaking. It feeds a plastic condensor bottle on the right side seen from the front. Hot air is blown upwards through the condensor and a leak can let water vapour condense on the inside of the case in that area.
1helpful
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Do I need a belt? It stopped spinning during rinse cycle.
IT COULD BE A BROKEN BELT , open front panel and take a look at the bottom , you might need a flashlight for more accurate visual , good luck , AJ
Spin cycle not running through stopping at different times eg 5mi
Front loader? Check out your filter & pump for blocks. Belt should be sufficiently tight, play of max half inch. And then check your motor brushes for wear. Power off the wall mains of course.
From the section i am answering this i dont have exact details of machine, but minimum is sufficient. Thats why i ask front loader?
And rate plz............
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Frididair GLTF1670AS Front loader washer problem-water will not run in
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
1helpful
2answers
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
