How do I add contacts to my phone. the add button is grayed out.
When I go to contacts there is not add button. When I go to contact the groups then select family then menu and add members the add button is grayed out. Is there some other way to add contacts?
In your contacts, select a contact you want to add the photo to.
At the top of the screen there is an edit "button", press that.
Then where the photo should be there is a "+", press that and tell it what photo to use.
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax. 2. Touch Send Now. 3. Touch the telephone symbol to access its phone book feature. 4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts. (Note: Contacts should be established before any of these could be added to any group.) 5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group. 6. Touch Name. 7. Changes to contacts/groups: •Adding a contact/group: type the name, & then touch Done. ••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create". ••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then... ••Editing a Contact: touch Fax Number, enter the fax number, & touch Done. ••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Click Gmail at the top-left corner of your Gmail page, then choose Contacts.
Select contacts that you want to add to a group, click the Groups button. , then Create new.
Enter the name of the group.
Click OK.
To add contacts to a contact group:
Select the contacts in the Contacts list.
Click the Groups button.
Select the group you'd like to add the contact to, or select Create new to create a new group.
If you have multiple addresses saved for a contact, you can choose which address should belong to the contact group by opening the contact and clicking the small arrow next to the group you'd like to modify.
Then go to Groups (tap 2nd icon button on the lower side of the screen).
You can then Add a Group and/or add a contact to an existing group.
Adding Pictures to Contacts
Go to People
Then select a Contact from the list (tap a name)
Go to Edit Mode. Tap the menu button beside the home button (outside the screen), and select "Edit".
Tap the Icon beside the name of the contact. On the Select Photo popup, select Gallery if you already had a picture for the contact. Or, Select Camera, and take a picture.
HTC Music Directory
If you connect your phone to a PC, you can browse for your music inside the "Music" directory. It was structured like this:
F:\Music[Band Name]\[Album]\Song Title (drive letter may vary)
How to Add Contacts to the LG Ally
1.Touch the "Contacts" icon on the screen of your LG Ally. The "Contacts" icon is at the bottom of the screen. The icon is a gray and white rectangle with a thin green bar across the top. 2.Press the "Menu" button on the bottom of the LG Ally and touch "New Contact" on the screen. The "Menu" button is the third button from the left in the row of buttons. 3.Slide the phone open to access the keyboard and enter the name of your contact. 4.Touch any of the information categories and enter the information using the keypad. Information categories include phone number and email address. 5.Tap the "+" icon to add more information categories, such as additional phone numbers or email addresses. Tap the button next to the new information category to access a menu of category names, and then enter the information using the keypad. 6.Press the "Picture Frame" icon on the screen, which is a white and gray rectangle with a "+" on it, and then touch one of the pictures in your album to assign that picture to the contact. 7.Touch "Done" on the LG Ally screen to save the contact to memory.
Groups can contain any
number of contacts, and even just a single member, so you could, for
instance, have one ringtone for family members, one for work colleagues
and one for your partner. To create a group, assign a ringtone and image and then select a group's members, follow these instructions:
From the main menu, highlight Contacts and click Select.
Highlight Groups and click Select.
Click Add (or if you have already added groups, click Options, highlight Addnew group and click Select).
Enter a name for the group and click OK.
Highlight the group's name in the list and click Options.
Highlight Group details and click Select.
Highlight Group ringing tone and click Select
Highlight Open Gallery, click Select, locate the ringtone in your gallery and click Select to apply.
Highlight Group image and click Select.
Click Add, highlight From Gallery, click Select, locate the image in your gallery and click Select.
Now highlight Group members and click Select. Click Add and your contacts list will open. Highlight the contacts you want to add to the group and click Select. You can add as many contacts as you like to each group.
If you want to add contacts to an existing group, highlight the group's name on the Groups screen, click View and click Add to display your contacts list. Highlight a contact and click Select to add them.
From the address book. press menu button select NEW GROUP . you can give a name to the group i.e family frineds etc. and have to add each contact one by one in the group. plz vote.
Address Book Contact List There are two ways to enter Contact List. 1. Tap the [ ] in the idle screen then tap Address Book - Contact List. 2. Tap the [ ] key in the idle screen. This menu allows you to save and manage contact address information. The Contacts’ functions allow you to add a new address or search saved contact addresses by name. New Contact This menu allows you to add a new contact address. You can enter contact address information including name, phone numbers, email addresses, group information items, memos, ring tones, and image (photograph). Favorites This menu allows you to have your own favorite contact list. You can add and delete it. Caller Groups This menu allows you to manage group information. By default, there are 4 groups: family, friends, colleagues and school. You can also configure a ring tone for a group so that the group ring tone sounds when a call from a specific contact address within that group arrives and there is no ring tone configured for the specific contact address.
You should be able to do this by going into contacts, hit the menu button, then choose Add New Group, enter a name for the group, then hit the menu key again. Choose Add Member, and select the people you want in your list!
By the way, you have to have the people already saved in the phone to add them to a group.
