Sorry no answer but can confirm I have the same issue with a DMR BS750 (same machine smaller hard drive ) connected to a Panasonic TX-L37G10B. DMR no BBC1 but BBC 1 ok on the TV have you had any luck with an answer? [email protected]
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
first you will need to go to
Settings > applications > and then checkmark unknown sources.
Then you will have to go to your file manager (like astro) and click on the .apk.
The android installer will run and install the app.
Betty,
Archos has been saying Flash would be officially available for some time now, but it's still not out. There is a beta version that I'm using, works great for me:
First step to getting Flash working is to go to your settings menu, then Applications, then check the box to allow for Unknown Sources to be installed.
To get a Beta version of Flash working use this link (from your Archos tablet):
http://ge.tt/36fA44X
You should be prompted to install this APK file on your Archos 101 after it's downloaded, this will give you a decent version of Flash (it's taken from a Droid X which has similar hardware to the Archos 101).
The Version number of your Archos 101 firmware is different from the Android Operating System. Version 2.1.8 is the latest Archos firmware as of Feb 28, 2011, this is Android 2.2.1.
To force an update, you actually need to connect the Archos 101 to the internet, not to a PC. Once you're connected to a Wifi network and have access to the internet, go to your Settings, then scroll to the bottom to About Device. On this screen is a Firmware Update option, this will check for and download the latest. Once it's downloaded you'll be prompted to plug your tablet into the charger and restart it to apply the firmware.
