I want the office phone lines that show and can be answered to ring in my office.
SOURCE: LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
SOURCE: phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
SOURCE: Samsung Prostar 816
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
SOURCE: cannot answer phone when it rings
when you lift the handset from the cradle try pressing the line number button on the handset or answer button on the handset.
