Dishwashers Logo
J
James Curry Posted on Feb 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The detergent door on my Aunt's Electrolux GLD9857AQ1 dishwasher doesn't latch. Is there an easy fix? I tried manually moving what appears to be the latch to make sure it wasn't just stuck, but that didn't help any.
  • 2 more comments
  • Brad Brown Feb 06, 2015
    Hi James Curry, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? That model number is not correct .
  • James Curry
    James Curry Feb 06, 2015
    Odd, that's the model number I got off the dishwasher. See attached pic. Thanks!
    That is a B not an 8 and the part is here:http://www.appliancepartspros.com/frigid...
  • James Curry
    Great! Thanks for the information.
  • Official Brand Answer 2,267 Answers
  • Posted on Feb 10, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290001
Points
2557
Hi James Curry, thank you for your post!
From the information you have provided the detergent door is not latching on your Electrolux dishwasher. It could be possible that the door latch is broken or door strike is faulty. You may need to replace the latch I would recommend checking over each component to assure there are no cracks or broken pieces. If each appears to be in proper working order I would recommend having a professional technician come out to review and provide an accurate diagnosis. This will help to avoid any unnecessary part purchases. If there is anything else that I can help you with, please feel free to reconnect! -Matt
1helpful
I have a Hotpoint FDW70 dishwasher and occasionally the detergent door/cover does not open. Press the correct buttons etc
Make sure the detergent door latch mechanism is clean and moving freely... If it is spotless, replace the dispenser assembly. Help Me Find My Model Number
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Nov 16, 2014 • Dishwashers
How to fix electrolux el 6115 door latch is faulty and doesn't click shut
It happens to skip latch and is no longer possible to close the door and turn on the dishwasher. The latch is in plastic material in which a system of levers provides the mechanical action.
Solution: Remove control panel and put latch back into normal position with the slot forward. Look the picture.
Dado
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
2helpful
Hi, I have an Electrolux E600 dishwasher and the detergent dispenser door has stopped opening. There's definitely nothing blocking it (the solution given in the manual). Any ideas appreciated. Tha
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
1helpful
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
1helpful
3answers
Detergent dispenser
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
