Health & Beauty Logo
Stacey Mills Posted on Feb 06, 2015
My supreme weigh digital pocket scales is reading LLL? What does that mean and how do i fix it?
1helpful
Why does salter scales round up when measuring grams
Because you have a scale that weighs in whole grams not parts of a gram. You need a more accurate scale like these which weigh to 1/00th of a gram (0.01 grams).
https://www.walmart.ca/en/ip/fashionhome-500g-0-01g-Weigh-Gram-Scale-Digital-Jewelry-Pocket-Scale-Backlit-Display-Tare-Function-Food-Weighing-Tool/531FGVNPN850
How to fix digital scale reading LLL
LLL probably indicates "Off-Level".Take batteries out / unplug power,re-apply power and make sure scale is Level....LLL also might indicate power is Low....make and model # ???
2answers
Digi weigh scale (hand held) powers on, then reads "LLL". Will not cycle thru calibration correctly . Can it be fixed?
Remove and refit the battery. this may reset it, if not replace it as the cost of repair will be more than a new one.
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
Y does my scale model # sw13 read LLL
That means that it is out of range. It is trying to weigh something that is too light. IT could be the sensor is bad or loose.
Calibrate a mega weigh mgp-1014 digital pocket scale
Calibrating a digital pocket scale like the Mega Weigh MGP-1014 ensures that it provides accurate measurements. Here are the general steps for calibrating such a scale:
Note: It's important to refer to your scale's user manual for specific instructions, as calibration methods can vary between different models.
What You'll Need:
  • Calibration weights (these are weights with known, precise values)
  • The Mega Weigh MGP-1014 scale
  • A clean, stable surface for calibration
Steps:
  1. Read the Manual: Familiarize yourself with the user manual that came with the scale. It should provide specific instructions on how to calibrate the scale.
  2. Clean the Scale: Ensure that the scale's weighing platform is clean and free from any debris. This helps to prevent interference with the calibration process.
  3. Power On: Turn on the scale and wait for it to stabilize, displaying "0.0" or the default reading.
  4. Tare (Optional): If your scale has a tare function, you can use it to zero out the weight of any container you plan to use to hold the calibration weights. Place the empty container on the scale and press the tare button.
  5. Select Calibration Mode: Many scales have a calibration mode that you need to access. Refer to your user manual to determine how to enter the calibration mode on the Mega Weigh MGP-1014.
  6. Add Calibration Weight: Place a calibration weight of a known value onto the scale's platform. The weight should match the unit of measurement you plan to use (grams, ounces, etc.).
  7. Calibration Procedure: Follow the specific instructions provided in the user manual to initiate the calibration procedure. This usually involves pressing buttons or following on-screen prompts. The scale will often ask you to confirm the weight value of the calibration weight you added.
  8. Confirm or Adjust: The scale should display the weight you added as the calibration weight. Confirm that the displayed weight matches the known value of the calibration weight. If there's a discrepancy, follow the manual's instructions to adjust the calibration setting accordingly.
  9. Repeat if Necessary: Some scales require calibration with multiple weights to ensure accuracy across the scale's entire range. If this is the case, follow the manual's instructions for using additional calibration weights.
  10. Exit Calibration Mode: Once you've completed the calibration procedure, exit the calibration mode according to the instructions provided in the user manual.
  11. Test with Known Items: After calibration, test the scale's accuracy by weighing objects of known weight to ensure that it's providing accurate readings.
Remember that the exact calibration process can vary depending on the scale model, so always refer to the user manual for the most accurate instructions. If you're unsure about any step, it's recommended to contact the manufacturer's customer support for assistance.
When I turn on my digi pocket scale modelDW1000BC it reads LLL what do I do
I usu and hold itally turn on scale for a short time then hit m
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
