Disengaged power to manual mode on/off then restarted. Tried to unlocked the joy stick by turning chair on. tap horn twice, then chair off and back on. No change, still get the 3 blinking wrenches.
It is indicating a left motor fault, which is not good news. This is usually from a motor overheating and burning out, usually from overloading the chair or from driving it on unstable terrain like mud, snow, wet grass or sand. If that is the case, there could be more damage to the electronics once you get the motor replaced too. Replacing the motor is a lot of work and very expensive, so you may want to try to find a replacement chair.
The man and the ranch are gray and first the man and the French were blinking now just the man blinks thank you and I don't know how many times it blinks too fast
SOURCE: wheelchair will not run. lights blink on and off
may have damaged one of the two motors or disconnected motor plug.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
