Jasmin
good morning to you . Yours is a machine that boils all the waterbed fore it goes through the coffe. I have had one like that and if my memory does not fail me, it stopped boiling the water and there was I tiny wee valve that had to be replaces. The valve was in the bottom part. Good luck, kolbrun
SOURCE: Coffee maker brews MUCH slower and makes less coffee
It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
SOURCE: Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
SOURCE: Bunn VPR 04276-0003
There is a thermostat underneath the top of the machine. There are a couple of little screws that you need to undo then you will see a little dial or even a little T on top of a metal box or circuit board. I recommend that you unplug the machine before opening it up. Then just turn the thermostat down - usually counter clockwise. Turn it just a little and put the top back on the machine and let it heat up.
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: Electric coffee maker no longer boils the water
As you explain i understood that heating element is in defect. Even if you don't find replacement in part DO NOT THROW IT. only remove electrical parts and you use it in direct heat , with gas or fire. buon apetit.
