It does not appear that this watch supports this function. http://mygshock.com/casio-manual/1286/
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
SOURCE: watch alarm
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: Do not know how to
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s) (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
SOURCE: casio wave ceptor WVA-105H
Casio is a great watch company
you can get online manuals anytime
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2734&submit.x=49&submit.y=8
SOURCE: setting the alarm of my casio watch.
Visit this site:
Enter the right numbers from the caseback and download manual for your watch.
Don't forget to rate, please.
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps 1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
