Hello mhitt,
Even though you have a pretty new copier, the ability to print the meter reading is not available. I know it's crazy since other copiers have been able to do it for years. Only the most recent models of Canon copiers have this ability. To print the meter readings for your copier would require that you go into SERVICE MODE and print a report that has several pages of **** and if you know what you are looking for you can find it.You could use the REMOTE USER INTERFACE (RUI) and view the meter and do a "screen print". I know it's not a happy answer but its correct. I wish you well. :-) By the way, the main meter reading (designated 101) is the count of sheets of paper that have successfully exited the copier regardless of size. My company uses meter "102" which counts 11x17 as 2 clicks on the meter. You probably cannot see this meter unless a service tech programmed it in.
Hello Ken, If the mem bank of printer is full it will slow down, go into Control panal on PC, hit Printer icon, highlight icon and right mouse click, go to prop click empty drafts and copies, and you will see the junk go in bin.
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Pull the main charge unit out of machine. Take cleaner (included with toner) and clean. --Look at front and rear for toner build -up on the charge grid. This build -up causes a short. After cleaning, reinstall and run.
1.On the drivers CD You must have Quick Config tool.Just click on setup Icon and follow directions.
2.Or just press "printer"Button on the operation panel of machine.Go to Interface-TCP/IP and You will see IP adress.
You can also from printer menu select "print Status Page" and page will be printed.You can find IP adress on the status page.
